Is there supposed to be some kind of bung/plug/breather or something in this hole? It seems to go down into the oil tank, and lets out a small drip whilst the saw is running.
I have parts diagrams but I can't see it anywhere! :sneaky2:
Saw is a stihl ms250
  • Replies 20
Fair bit of heat being generated there to cause that burning.Is that normal?
It's a MS-250, with a plastic body - not alloy like the 260. Hence the discoloring.
The hole by the exhaust seems to meet up with the normal hole for the guide bar (so not into the tank).
I just can't figure it out. I tried blocking the hole with a short thick screw, and with the bar off, oil streams out of the hole for the guide bar, as it should. But when you put a bar and chain on, the oil doesnt seem to run along the bar. The bar and oil hole are totally clean, and I even tried a different bar. Also tried blowing out the hole with an air line
