When you put a vid on youtube, you grant youtube and its users the right to use it.....[ame=http://www.youtube.com/watch?v=AdcK6r7yk9Q&feature=player_embedded]YouTube - Who Owns Your YouTube Videos?[/ame]
howd you rig it so you only use one hand? I`ve same machine,,be better if ram was faster,,,,
Yeah fancy them putting my non CE compliant version on there!
On the back behind the arms is a metal bar where the two arm levers stick into and that lifts the connection to the hydr valve. Where the bolt is running thru the centre of this horizontal bar it clamps the s hook at the bottom of the ram control chain; wind this nut out and put a fat washer between its' head and the s-hook and tighten v tight but with the horizontal control arm up at one end - whichever end you want to use (i.e down at the right in mine) and then tighten even more and then fully tighten the lock nut too - will last for a while but needs retightened sometimes... will take pics
