cs 39 help
Alasdair
hey all how we all doing?
ok guys ive got cs 39 coming up soon once this is done that me back out into the big bad world :scared1: so basically im looking for advise on how not to make an ar$e of this test? i know work position it the important thing which im getting that hang of but is there anything that will help me?
cheers
ok guys ive got cs 39 coming up soon once this is done that me back out into the big bad world :scared1: so basically im looking for advise on how not to make an ar of this test? i know work position it the important thing which im getting that hang of but is there anything that will help me?
cheers
Empty your mind of unnecessary clutter. Move methodically and ensure you are positioned correctly, secondary in place etc. Be really sure of the terms that will be used. It might be helpful to run through what you are about to do in your mind first, like a little movie in your head.
Be really sure to do exactly what your supposed to do and not show off. Finally, use the force. good luck chap.
Have your chain a tad tighter than you normally would, or apply your chainbrake before your remove the bar from the cut, (you can't have the chain moving as you remove the saw from the kerf). Try and relax, get a comfortable work position and LOOK at the cuts as your doing them.
You've got plenty of time so just take it easy mate - good luck!
