how do you improve saw performance
Breezeblock
  • Replies 21
as the titlesays what do you need to do to increase the power output of a chainsaw and how do you know when the mixture is correct:confused1:
As said sharpness is key, but if you are unsure or not been shown how to alter the mixture settings best to leave alone or get instruction. If you run the saw too lean it's possible to do major engine damage. You can refer to your manual for basic settings; typically 1 1/4 turns out on a Stihl on the H and L the other screw is idling. I have a feeling there is a video showing you how to do it either on Arbtalk or Youtube maybe someone will post you the link.
port the exhaust. do a search on google or here...
and by mixture i presume you mean 2 stroke/fuel? well, it's 1:50 so, 100ml of 2stroke in a 5l combi can of unleaded....
not the 2 stroke mixture the actual air / fuel mix . when an engine is tuned i would expect it to run faster under load ie because it has more power but how do you set the mixture for a tuned engine because you wouldnt have the same airflow as a standard engine so the normal setting that were in the manual wouldnt be relevant or would they:confused1:
