Advanced chainsaw maintenance
APC
What else are you wanting to know?
They are pretty simple machines, and really havent got much to go wrong.
As far as i know these courses dont exist, but Arbtalk should have most bits covered- check out Dean Lofthouses latest vid about carb rmoval on a 200t for example.
I dont see the need to send in saws for service if you are competent enough to service yourself.
All you are required to do is keep a service record yourself, what was serviced, what you did and when.
A service on a saw is airfilter clean, fuel tank and filter clean, oil tank clean, spark plug change, fuel filter in carb clean and settings check (Hi Lo jets with tacho) and a general check over mounts etc
Why are you "required" to keep a service record? Is it Puwer regs or soemthing? I keep a record in my head of what has happened to what and what spare parts I have, it leaves little space for much else in there but it works for me!!
