Theoben Fenman .22
Remington BDL .243 Varmint HS precision stock Jewell trigger T8 reflex moderator bedded in Devcon sub 1/2" 5 shot groups with handloads 0.3" with some
Ruger 10/22
The important 2 the team jacket is for Trap shooting DTL 2009 and ABT 2001 and 2002
  • Replies 126
just a webley raider .22 pcp single shot just inside the 12ft/lbs limit, enough to stop bunnies.
Same here except mine is the two shot model.
Did consider taking it FAC as it is very easy but the consistency suffers badly.
At the min if I fill it to 195bar (and not the 210 bar max) I can get over 50 shots all within 5 fps of each other.
Couldnt resist it ,did you have a good christmas matey,im actualy looking forward to getting back to work if i eat much more i wont be able to pull myself up a shrub let alone a tree,and be careful using expletives like REDRUTH,mr bulman will be sending you a message,naughty man lol happy new year cheers DB.
I had a good one my friend, I'm like you, I've had enough now, I've been up in the wood today getting a couple of loads out, everything seems a bit tighter than before Xmas though. All the best pal.
Obviously you're into your shooting in a big way Scot but why have you gone for a semi-auto for bunnies and not a bolt action? Assuming the 10/22 is for bunnies.
Thats one reason:001_smile:
The 10/22 does everything i need it to. Its been accurised a bit, The headspace in the bolt has been reduced and the trigger modded to just over 2 lbs 1/2" at 50 yards with Winchester subsonic hollow points.
Yes it will jam now and then but if kept clean it will work perfect for about 200 rounds.
Its nice to just keep looking through the scope and picking the bunnies off ive never felt the need for a bolt action .22
The 2 mags glued together is awsome for in the truck at night, Just flip it over and fill when you get a chance then flip it again and you have 1 up the spout and 10 in the mag ready to go plus you dont lose the mags by setting them down!
  • 1 month later...
Not an air rifle in sight.....From the top; .308 (7.62 NATO) Remington 700p in a Bell & Carlson stock, barrel cut to 22", 10 rnd mag conversion, Badger tactical knob, (:laugh1:) Leupold 4.5-14X50 'scope, Harris bi-pod; FN SLP (self loading police) semi auto 12g shotgun; Mossberg 500 12g pump action; AK47 (with telescopic stock); Ruger 10/22 with mental 25 rnd mag.....
Edited by TheTreeWiseMen
