Petzl Sequioa Harness
Amelanchier
  • Replies 48
it is a dream to put on, to get off, you can actually walk about and forget you have it on. Normally you hit the ground have a moan and recover then drop the harness, this fella you are quite happy to start cross cutting or something. Best harness so far, loads of areas to adjust and make even better. may put a second swivel onto bridge, just to get that oh so sexy clanging noise. Then you know your goin somewhere
'Twas 11mm Velocity (applied with violence, frustration and anger) and the ends are secured with a rather ad hoc mix of insulation tape, shrink wrap and whipping. The whipping is the key, stitched parallel with the bridge, which allows the paw to slide over it without catching.
A product of trial and frequent errors... :D
I've just bought the sequioa SRT and find it very comfy. One thing that does slightly worry me though is the screws coming lose in the gold gates. How is everyone finding these? Are they holding up to daily use?
Also, something I've noticed in the instructions that you get with the harness is that the attachment bridge and each side D ring are only rated to 15kN. This seems quite low to me considering most karabiners are rated to 30kN. Any comments.
Thanks
Gary
You will be attached to both the side d's at one time or to one side d and something on the bridge. 15kn X2 =30kn.
your not meant to hang off your side d's anyway.
