so it's begun, am fitting the winch to the D3,,, expect chaos for a few days while i try to figure it all out,
so far, grill and lights are off, at present fighting with the wheel arches..
will update with pics along the way..
  • Replies 41
so,,, here's the plan,
1.split charge system and second battery- optima yellow top.. normally this would cost region of £450 . plan on it being done for under £50, my pops is a sparky and has sourced most of the bits i need, also have anderson connectors for rear.
2. winch mount,, this is an OEM part made by WARN for LR,, it's an external mount as i reckon having a hidden one in this game is asking for trouble, maintenance would involve removing the front every time.
3. replacement bumper. managed to get one for £20. it's black but as most of it will be cut off who cares... this is the bit i'm on now. coping saw and a ruler..
4. sump guard. managed to find one in a stealer for £50.. lightly used but again,,, who cares..
if i got this all done by LR it'd cost over £2500.... i should be coming in at under £700....
more pics to follow...
i booked mine in to the garage for this friday to get my winch fitted:blushing:
a D3? you should do it yourself,,, best way to learn about your landy is to take it to pieces...it'll save you a fortune...
