Can I have some help please I'm thinking canker but no obvious bleeding lots and lots of heavy " scarring" on second to last pic see how the scarring seems to or has "crumbled away " leaving limb barley holding on . ImageUploadedByArbtalk1408114354.495525.jpg.4b772ad3bce925addcc73ff2d7977d8f.jpg
looks like canker
Big sycamore with dryads saddle, the centre section was sosoft you could punch it and leave knuckle imprints, mature I know!
Ground level not a mark in the stump, perfectly white but from 8ft up till the crown brake just sponge inside. All off for habitat in some other section of the estate away from the main grounds.
looks like canker
I'm inclined to think so but surely with such excessive scarring there should be signs of bleeding ? If I'm missing something I'm happy to be put right
'if' it is Pseudomonas syringae pathovar aesculi, the infection has been known to cease. So bleeds may have dried up.
But the cankers on your example may have been caused by a n other pathogen not associated with the bleeding symptom.
Try using the search function for threads specifically on HC bleeding canker
