It was a 10 inch back leaner at the original felling cut but it had too much weight so sat on the bar and i didn't have the strength to lift it the other way. So did a dog tooth about 18 inches about the original cut to fell it the other way. The tree was only about 7 inches wide there so did a small gob, bored in and left a very small bit of holding wood on the back. I couldn't do a simple fell as it would have barbers chaired on me.
Still don't get the "ballsy" bit?? what did your instructor think was going to happen???
Under cut is a little flawed, back cut lower than hinge? Cant tell...
He thought it was going to do a simple cut but decided to do a dog tooth with no room for error. The bore cut is slightly lower than the sink cut but only by a tooth width. I was in training then and was the day before the assessment.
It could be the camera angle or the fact i didn't cut the hinge off flat.
Forward leaning sycamore on a woodland edge. Start the back cut, bang hit a nail, move up an inch, bang hit the SAME nail. Chain now bit knackered. Managed to bore through to sort of create a dogs tooth cut in the wrong order. Was expecting a small breeze to catch it and make it barber chair before I got the bore cut in.
Another one in the same group. Slight hole in that one.
  • 3 weeks later...
[ATTACH]149792[/ATTACH]
[ATTACH]149793[/ATTACH]
A leylandii fell from last week
[ATTACH]149795[/ATTACH]
A spruce
I know this post was a few weeks ago, but can I ask, were you taught to fell like that or is it just something you've seen others do?
