im not sure if its me or not but today while using the chipper the bottom feeder roller seems to me like its dropped down more than usual ? everything still works they both rotate an the top one goes up and down like it should but it still seems like its to low as i never remember being able to look through and see the anvil ?:confused1:as far as im aware the bottom roller is in a fixed position right ? any ideas or is it just me being paranoid ? its a entec chippet if that helps
Could be something ie big lump of chip wedging the top roller up.we had this on a greemech,for days we could smell burning wood,and then without warning it cleared itself,we usualy find that putting a lump as big as the chipper will take,will often clear any offending object.
Make and model would be helpful. Is the machine still dragging small stuff in?
The bottom roller can drop if a bearing fails but it usually goes on one side. As a quick check with the engine off put the feed control in the stop position and put a pry bar or similar between the anvil and roller there shouldn’t be any movement other than a little rotation.
Are you sure it’s not the top roller not getting all the way down?
Andy
yeh i did think that maybe a peice of chip was wedged somewhere but because everything is still running i havnt investigated further :sneaky2:it does seem that when feeding it there is a clonking sound when the top roller goes up and down like its sort of a bit jolty ? instead of a smooth feed :confused1:
Andy
no the small stuff is a bit of a pain by small i mean say less than an inch, the bottom roller is dead flat not dropped to one side , its gota be the top one then hasnt it ! if i hadnt started work at 5 30 this morn i would have taken a few pics and had a further look but all that went out the window when 5 oclock came around !
