i happened across a couple of goat willows today with a lot of damage. There was a lot of ants around the trunks so i wondered if they were the culprits. i dont think it is however as the the holes seem too big.
any ideas?
I reckon that the ants have moved in after something else has made those holes. They look like the sort of holes i see quite a few of when milling, and there is usually a big fat grub in them. I have come across wood wasp larva in larch (i dont think that yours is that) and in hardwoods esp oak I have seen what i think may be goat moth larvae, which make holes similar to yours.
edit- i have just read the wood wasp suggestions......i have only seen this in larch sapwood. Didnt know they attacked other woods.:001_smile:
You're right Tommer, the Wood Wasp most commonly encountered here is Urocerus gigas, the huge black and orange beast that sounds like a microlight but is totally harmless.
It's larvae does feed on softwood, I've only ever encountered it on larch but it will feed on other softwoods such as Abies and pines.:001_cool:
Microlight- thats a great description. I heard one above the noise of the (idling) engine on the mill one day. I thought something had gone wrong until i saw it flying about!!
Tommer said"I have seen what i think may be goat moth larvae, which make holes similar to yours...."
Never seen goat moth caterpillars in "gregarious" burrowing...ie, alot of holes together. It was my first thoght. I guess it's hard to know quitye what sequence of events has occurred here. There is obviously quite a bit of debis associated...
Goat moth.So called for it's smell. Cossus cossus.
Goat Moth Cossus cossus - UKMoths
