im assuming that was its purpose. never come across it before
No me neither but the more you think about it the more it works. Same principle as a dogs tooth.
  • Replies 76
am i right in thinking the gob was cut, then bored through to create hinge, then the last cut low for some reason i cant work out yet, they jump because the gobs have closed up..?
No, the bottom cut is the only back cut (I think) in effect there is no hinge.
exactly, Ihave seen a vid of that technique b4 and used it, the dog tooth was developed for forestry use and minimum wastage, that technique requires felling higher so no good for forestry but fine for us.:001_smile:
nope, look again, there is a hinge where it should be. its all in thirds roughly. gob is a third, then the hinge, then the back cut...at least thats how i see it
:blushing: Right I see now!! :001_smile:
I'm confused by it. A shallow gob and normal back cut would done the same thing. If he was worried bout tearing he could use kurf cuts. If he was worried bout barbers chair then a dogs tooth? Is there a bigger picture I'm missing?
Oh yeah Americans. Haha
