Thanks Monkey. Now that you mention it I can see the similarity :o ha. Cool stuff though! Some of the fungi in this thread are amazing!
  • Replies 83
How about a guess at the base of this Giant Sequoia. I don't think its mycorrhizal. Probably decay related. There were several other rows of mushrooms among the row of trees that appeared mycorrhizal, extending radially where roots would extend. The climate is right too. But this cluster looks different. Its the only trunk with a base that looks like this.
Edited by mdvaden
hmm, doesnt look mycorrhizal to me... but as for the id, im not sure? :confused1:
any other clues? signs/symptoms in the tree?
The foliage is less dense than most of the other trees in the rows, and its also one of the shorter ones.
That one looks like the only trunk where the base not not broadly widen where the base meets the ground, especially on the side of the mushrooms.
There is also a sprinkler sticking out of the ground about to the left that is not in the image. A small popup like a Toro that's on a tiny riser instead of the sprinkler body in the ground. Not sure what it would water. It looks a bit small to reach much of the grass outside the mulch ring.
The mulch rings are the Giant sequoia needles for each tree, about 6" thick in the outer ring.
Edited by mdvaden
  • 5 weeks later...
looking at that body language lower stem i would say its a decay fungi, but that constricted look could aslo be via a girdling root. looks suspect to me iether way/
