we deliver them on iveco, load with handler then tip the iveco slightly and get 2 guys 2 grab and handle each, if you pull it quick the logs stay in and you can then drag to final destination
if there is a lip on the edge of the vehicle one guy can grab the rear two handles and pull and it will dump them in a nice pile on the floor
they must be smallish bags - builders bags? - as believe me, you couldnt move our drying net bags each one is shaken with the loadall as its filled to really pack them in - even when dry you wouldnt even move it with three or four people
I load with a tractor and deliver in 1m3 bags that tie at the top, 2 fit on the tipper and i simply just tip them off as you would a loose load, never had a problem yet. customers simply put a knife along the bag to open them. A few hav said they prefer it like this as there is little mess on there drive with having the tops tied up.
i can shift my bags myself, you need to get to the gym Mr baron:biggrin:
ic, do you use the mesh cubic nets, that fit into the frame, like a big log net bag? with the pull cord around the top? weve got those also - logs dry really well in them
