my first coronet atempt
testcricket01
part of todays job was to remove this limb, because it had been sheding branches off it through the BT cable and blocking the driveway. since it was a biggish limb bout 15/20inch i thought id try leaveing a coronet instead of a normal cut. my first time doing it so any feedback welcome :thumbup1:
Not bad at all. I would have slashed up that little stub too to avoid having a flat cut and coronet side by side though.
How did you find it with regard to work positioning?
yer i thought about the little stub when i was up there but came down see what it looked like and forgot about the little stub.
work positioning was not a problem at all there was a few stubs left from previous work by someone so i stood on them and anchor point was right ontop of it. :thumbup1:
