Modifification done.
Huge high impact nylon wear pads spreading the load over a wider area rather than concentrating it in four small pads, so should last many times longer, whether greased or drylubed :sneaky2:
That looks good Dean and better than origional, should be spot on now but use grease mate:001_tt2:
  • Replies 55
Decided to go with chain oil after all :laugh1:
Put it all back together and I had taken upany play the was, so things were a bit tighter than I thought, so I mixed chain oil with drylube and it worked a treat
Only thing I'm not happy with now is how when I put the four way adaptor on it blunts the single main knife.
I had sharpened the main knife up like a razor, stuck the fourway on which slides over the main knife and it flattened the edge off after one stroke
