  • Replies 40
I think you have to use common sense when bracing and you need to look at what would happen if a failure occured. However, bracing should be inspected at regular intervals and if that is done there shouldnt be any problems
Trouble with invasive bracing is the damage, obviously. No amount of inspections are really gonna do more than tell you that failure looks iminent...the damage is already done.
I think I might have turned the work down Steve...easy to say from where Im sittin' !!?:icon14:
For sure you gotta reckon it does not make the wood weaker...and so more likely to fail. I guess reg inspections at least informs as to reaction wood around bracing sites etc. There is a reason we use non-invasive bracing afterall...but this system would really need inspecting in the same way IMO...?
I have not done a lot over here, this was a Silver Fir I did in Germany in 2002 in the grounds of a drug clinic (:heeeelllllooooo:) I think we used Libra and then went on to Cobra.we took a few feet of the top and put a fairly loose brace in about two thirds up to stop swaying .There was a third stem that had snapped off where the 30m tracked cherry picker dropped me off at full reach (!)
... I was glad to get out of the cherry picker - I think it swayed more than the tree!
59765353d876d_silverfircopylargewithhighlight.jpg.0ea843c2bb22646fef2ab1258aa161f4.jpg
That it was!, I went back over to the left of the pick after i took the tops out , and tryed to make it look a bit more natural . But it 's never going to be as good as before,probably should have left the tops in but thats what he got advised to have done.There was a huge Magnolia right underneath ,that he did,nt want flattening ,i thought about lowering it (for about a second) so i let them go ,luck was on my side and everyone was happy.:icon14:
