25 minutes ago, Macpherson said:
Yep agreed, I just checked the current price and I doubt if I even consider either the 220 or the 300 at todays prices, but the 220 Is my go to saw for firewood, although I'm also liking my ancient Husky 154 at the moment.
I'm curious to know what the battery life is like on your saw with the 300 battery, I get about half an hour blocking up typical birch, but easy all afternoon if just randomly clearing small scrub as the OP requires.
I did also recommend the Makita😉 cheers.
Dunno, I only have 500s. 😂 Seriously, I'd say similar. I have enough batteries to usually cope with most jobs in the field, and I know that it has enough oomph for bigger logs/branches.  Like all battery saws, low current drain = long life. Make them work hard, and the battery life drops off quicker, relatively speaking.
Yep, I'm retired now so my saws are only for personal use but I could really do with another battery, I know that the 500s would do my saw which I've had for 6 years but at £350 I'm swithering although at some point I'll need to bite the bullet.
As you'll know the key to the efficiency of these saws is making sure the chain is always razor sharp and I've gotta say that I get a real buzz falling a big tree with what many think is a toy.... while they watch🙄
I don't know if your saw is the same in design as mine, but I've found that a definite potential trouble spot is that woodchip makes it's way into the inside of the sprocket/ brake so whenever I've got the cover off for cleaning I pop the E-clip and always find chip under the drum and I don't imagine that the oil pump gears are very  robust so well worth doing. Cheers.
Nope its rubbish.
A tree surgeon I know, broke his ms151t and bought the 18v Dewalt, no power and not many cuts before it was flat. Ruined his day with him having to stop climbing and do ground work with big saw - he was supposed to be topping a tall conni hedge.
11 hours ago, Projumper said:
What about the 18v Dewalt, as I have already a couple of batteries?
Regardless of the brand, I wouldn't recommend any 18v saw, it's just too hard work for the battery ( unless perhaps it's that mahoosive 12Ah Makita jobby 😄 ). Lower voltage means higher current for the same effort, and high current draw is the enemy.
Thank you for mentioning this, I appreciate that, as I am very much V over IR man..
On 02/02/2026 at 06:58, Projumper said:
Yeah, I have ultrasonic cleaned the carb, fitted a couple of diaphragm's, fuel feed and return pipes, tank filter etc, I love all this kind of stuff.. I'm starting to think down the lines of, its the mag that's breaking down!!
I am looking at the Stihl range..
Dyslexia is an amazing gift in many ways, for me I have to reread everything I write, and it still comes out jumbled up!
I have just stripped the carb, and ordered new pipes, and a diaphragm set..IMG_4161.thumb.jpeg.0a8e5c79920277bca15d70373cec5072.jpegIMG_4161.thumb.jpeg.0a8e5c79920277bca15d70373cec5072.jpegIMG_4164.thumb.jpeg.558e805dd24ea4027cb606ade2da8937.jpegIMG_4167.thumb.jpeg.c7051d5732af62023d4b21224ba4fcbe.jpegIMG_4169.thumb.jpeg.b3534c011843e4ff53bd034320391f89.jpegIMG_4166.thumb.jpeg.617857f8d1b1c72906a35fc188a0a78a.jpegIMG_4165.thumb.jpeg.b5a3ca1e0f563da31b23bb11a9d3ad79.jpegIMG_4168.thumb.jpeg.5d57c84f8834363ffecd5a30c7f14ae3.jpeg
