Over the course of a year- polesaw, blower and a 135.
All not used for a year or so, so drained of fuel and refilled with fresh good mix beofre staring. Each one has scored the bore on startup and is now scrap.
WTF? I never had this problem with Stihl! I'll never buy Husky again.
It must be something to do with the current materials used, I have saws that have sat for 30 years [and certainly without the care and attention you provide] never had an issue such as this, and that includes many Husqvarna models.
Sounds like they need storing with a bit of motor oil poured into the cylinder and cycled a couple of times.
I'm guessing the cylinder rings have rusted as everything else should be aluminium alloys.
Run on aspen or motomix , won't get these problems
I run any two stroke that doesn't get used often 100% on aspen.  When I store my strimmer over winter I run it dry and then refill with aspen, purge pump and run it again for 5 mins. My go-to chainsaw gets used constantly on pump mix and never seems to be inactive for long enough to have problems.  135s are pretty much disposable chainsaws, what model are the others?
What does "scored the bore" mean, have they seized, were they seized or scored when left on the shelf last year, is it carbon damage and who diagnosed the damage? It is possible that it is just normal wear and your repair shop is egging it up.
I have saws, Husky and Stihl that haven't run in 1-3 years that will fire right up when needed. The oil in the fuel usually protects the engine parts.
Both the manufacturers use very similar materials in their pistons and cylinders so not sure why these issues have occured.
I have 'shelf queens' that are only started every 3 4 or 5 years or so with no issues. I run them dry after using and store them in a temperate climate. Not too cold and not too hot.
All three were laid up in perfect health. Started up after changing the fuel and wouldn’t run right, started to need throttle to keep idling etc.
Pull them over and it’s clear the compression has vanished. Remove exhaust and I can see scratches everywhere.
I have multiple stihl  machines stored for similar periods without use and have never had a problem. I’m perplexed.
The polesaw has been replaced with Milwaukee m18 which is a massive improvement in performance and I’ve just ordered the m18 back handle.
Edited by doobin
Stored with all the rest of the machines inside an insulated workshop.
I don’t have to patience to do that on every machine.
My fs461 and fs490 are stored with normal mix in and never have an issue over ten years.
im just at a loss as to why three Husky machines have failed like it.
