Sorted the problem today. To cut to the chase the sprocket cover was damaged which was causing the bar to pinch the chain. I will go into some boring detail later when I have a bit of time.
The long winded version.
Slackened off the chain so its hanging a lot and after a bit of messing about I could see that the chain was getting pinched at the top of the guide bar. I turned the bar and it did the same thing, the sprocket cover and guide plate (this thing in case people are wondering what it is
SKYLANDEQUIPMENT.COM
Replacement chain guide plate for the Husqvarna chainsaws listed below. FITS HUSQVARNA CHAINSAW MODELS 545 MARK II, 545G MARK II, 550 XP MARK II, 550 XPG MARK II...
In this photo you can see the cover was scored along the top probably due to a thrown chain. )
Although the surface didn't feel raised I gave it a bit of a tickle with the angle grinder and boom, job done.
The amount of material that I removed was next to nothing but enough to cause an issue that I haven't came across before.
BTW Im not going to tell the customer that I repaired the cover I'm going to just bang a new one on for the handsome sum of £92 quid.
I hope he doesn't use Arbtalk! :D
Edited by Mark_Skyland
2 hours ago, Gabriel82 said:
@Mark_Skyland Isn't that a casting defect?
If you read what Mark wrote you will see its not a casting defect but the casing was scored from a thrown chain . He did a quick repair by removing the burr and scoring that was causing the problem . Aside from that , a 395xp is a cracking  ( old school now ) saw that is tried and tested . I have one ( Crocky ported )  and have had 2x 394xp as well over the years .
12 hours ago, Gabriel82 said:
@Mark_Skyland Isn't that a casting defect?  How is the "new" part showing?
I thought Husqvarna builds quality chainsaws for fcks sake...
And I was thinking about a 395xp...
Not that the current Makita EA6100 P is doing anything wrong...
As Stubby said it was user error rather than a manufacturing issue. The 395XP is a really good saw. I have a brand new one knocking about that has a cracked crankcase, I should really sell it on or fix it up. It will be the last of the 395's.
On 14/11/2025 at 22:39, Mark_Skyland said:
I was only joking. I charged £20, he's a good customer and I learned something.
Probably cost you £20 in labour time writing this thread. 😁
Probably did! £20 labour soon disappears once you take the machine in, tag it up write out the quote and phone the customer, usually several times, never mind repairing the thing. Hopefully it will help someone in the future if they come accross the same issue and this thread.
