I need to upgrade my tired old hydraulic log splitter, and my budget would just about stretch to the 15 tonne petrol C-Series.
I’ve never seen one in action, and the videos seem a bit hit and miss.
When splitting horizontally the controls seem a bit of a ballache, twin handles nowhere near the log?
Some videos show the ram speed as painfully slow as well.
Are they more user-friendly in real life?
Can they be converted to one handle easily enough?
I’m used to my vertical splitter.
My mate has the Oxdale SE400 which is fantastic but too big and too expensive for my needs.
Any input/alternatives appreciated.
Must be petrol.
Thanks.
I have the 22ton road tow splitter with table. Never found anything it could not split. Use it horizontally in the yard, occasionally in vertical mode on site for rings that need making smaller to allow moving by hand if we can’t get bigger machinery in. It sips petrol slowly. I rate it highly.
I have the very same model and I agree 100%, starts 1st pull, works all day and nothing has beaten it yet.
That’s good to hear, although I’m happy to sacrifice splitting power for more compact size.
I’ve muddled through with a 7t for years!
What’s the ram speed like?
a feckin' sight better than a creaky old bastard with an axe.:thumbup:
and dead easy to convert to single lever operation.
Edited by Oldfeller
  • Haha 3
Mark swapping to single handed is no big deal, I initially used a piece of flat strip bent to a U shape and then welded a bit of tube on top, basically linking the two sides of the old handles to one. It’s easy to visualise if you have it in front of you. The old spool valve died so I recently put on a new one with a proper single handle set up. Not expensive to do.
I’ll try and dig the old handle and valve set up out and put a pic up but you can just see it in one of the pics here.
one thing I should mention, when I converted mine to single lever operation It retained the option to stop the ram returning all the way, so in effect if you're splitting logs half the length of total ram travel you are effectively doubling  the ram speed as you only need to return it halfway.
I'm not sure if your current splitter has the same operating functions.
It more depends how far you throw the lever before it engages the auto return function.
You can alternatively reduce the nut on the side of the pressure valve to make it stop at a lower pressure, fooling it into believing that it's fully retracted at and point.
