I'm in the same position as you, Muddy. Take the plunge and report back please. £52 for the one you posted would be nice. Only difference is I would be happy to spend £200 if it gets me something of better quality, even if still manual.
Edited by AHPP
1 hour ago, GA Groundcare said:
Buy a proper garage tyre machine, we picked one up used for £200 with a wheel balancer out of a local garage. Have changed countless chipper tyres with it. Fit our own van tyres also.
They take a fair amount of space and are heavy to move, also needing power or compressed air. Wouldnt have been practical for me, I have extremely limited space.
5 hours ago, Muddy42 said:
I change a lot of small tyres - mowers, quad, trailers, wheelbarrow etc.  Some tyres I can remove with basic tools, a vice, lubricant and lots of swearing, but some defeat me.  The local garage doesn't really like changing small tyres and they have taken two weeks so far to do the last one and no doubt it will be expensive. I can fit valves, tubes, patches, plugs and all the other bodges for non-road use. Can anyone recommend a manual tyre changing tool for small tyres? Something like this?  Thanks
Or if you were really stuck you could do this, but proper tyre lube makes it easier.
https://www.youtube.com/watch?v=bWd5vwUeYno
What about one of these, seen one being used.  Designed for the kind of size wheels you're talking about, from 4" to 13" I think.
WWW.REDSTONEUK.COM
The TC811B is also a new design of an existing concept. With previously manufactured machines, the height below the bead breaker is...
Don't know price mind you.
Website says to log in to see price. Crying out loud. It's a tyre machine, not a coach built car.
Probably because they're trade only, give them a call.  Might be an option for buying your tyres too
Edited by NJA
Never had a problem if a puncher needs mending anything from barrow to 38in tractor but just get company to fit new on truck and trailers.,
Went to have a ifor williams trailer tyre mended once and fitter said you can't do them with leavers, I said why so once he broke bead he handed me two leavers and said have ago, that was a challenge I was not going to miss. After about a couple of minutes tyre had parted from wheel and tyre fitter stood there shaking his head, he had set challenge to others and most only got one side off.
  • 1 month later...
I’ve used a manual changer similar to that Vevor setup for mower and quad tyres — it does the job once you get used to it. The trick is plenty of lube and good bead clamps to stop the tyre from walking while you lever it off.
For smaller rims (like barrows or garden trailers), sometimes the changer’s center post is too big, so you might need to make a sleeve or adapter. The Vevor’s decent for the price, but if you’re doing a lot of really small stuff, the Harbor Freight mini tire changer or BeadBuster XB-450 are both handier and faster.
What’s the smallest rim size you usually deal with? That might change what’s best for you.
On 01/09/2025 at 12:16, Muddy42 said:
Generally its re-mounting a new tyre. I can break the beads by getting all the air out then jumping on the tyre.  Agreed I use lots of fairy liquid and push the tyre into the centre and any old compressor seems fine.  A ratchet strap can also help temporarily force the rims to seat while you put air in.
Small tyres tend to get flattened when they are packed for transport, it definitely pays to "round" them out by putting an old inner tube in a few days before you fit them. Warm tyres are easier to fit than cold tyres. Three tyre levers are better than two and leaving a small section of bead unlubricated stops it sliding round after you 😉
