I think the idea of using an impact driver as a way of managing the reaction torque is novel. To me it does have the whiff of snake oil about it, if you could suddenly increase cutting tool performance and life by a factor of two then people like Dormer and Sandvik would be all over it. After all cutting tools have been thought about a lot, by a lot of people.
I suspect they are twice as good as cheap tat, and more equivalent to the decent ones that few people buy.
Just try one they are not cheap but a lot of steel fixers use them no pilot holes and drill straight through 20mm thick steel you need high powered impact 1/2 or 3/4 drive and plenty of cutting grease it’s a easy tool to use especially up in a cheery picker I’d link a video but haven’t a clue how to
I can see the logic behind an impact driver for something like this, you’re limiting the torque that can be transferred to you, avoiding the whole thing binding up and bogging down. But optimally I’d still go for one of the big 36v drills. The makita twin 18v has more torque and higher speeds than the Milwaukee or dewalt I believe, and is nails. Mines been thoroughly abused and hasn’t skipped a beat.
Have you looked at looping steel cable round the stem with vertical timber spreader bars under the cable? Save a lot of hassle drilling then, has worked well on trees that previously would have had rods or been drilled and cabled. Or Treeworker will sell you very high MBS dyneema bracing material if you want a static splice- able set up that is stronger than any normal Gefa, cobra or marlow braids.
An impact wrench with 500nm of torque will stop turning a big auger long before a drill with 250nm.
Impact wrenches provide jolts of peak torque to fulfil their design function of loosening or tightening a machine thread. All that happens when you stick an auger on them is that the tensile strength of the wood fibres absorbs the jolt of toque and the auger fails to advance any further.
Impact drivers are use to drive screws into wood, yes, but the purpose of the jolts of torque there is to prevent cam out- where the driver bit slips in the head. Driver bits with a positive lock on the fiuxing head (such as timberlocks with their hex head) do not require an impact driver and will in fact drive far faster with the sustained torque offered by a drill.
I must have explained this a dozen times over the years on here, and yet still people just can't grasp such a simple fact.
A long arm brace on a quality drill allows you to impact far more torque into a wood thread or auger bit than you ever could with an impact gun.
