There’s been a few posts over the years about getting the bigger saw up the tree.
It can be a chew, especially at the end of the job when cramp and fatigue can be an issue.
I usually lay the rope over the stump while pulling up, so at least if I want to pause for a rest all I have to do is place my hand on the rope to give me 30 seconds to re-gird my loins (or forearms in this case)
I am all for making life easier, but how hard is it pull up a 70cc saw 30 or so feet?
You can do the same thing attaching any normal pulley, or just a carabiner to your harness bridge, tail of rope and sending down a loop.
The problem is you need 3x your height in spare rope, and I'd rather use shorter ropes.
3 hours ago, AHPP said:
Clip a foot/knee ascender in if you're worried about that. Help bring the saw up with your leg.
I don't want a groundie tugging me off, thanks.
or the rigging rope you already have hooked into the tree? thats usually what i use
I get stuff gunned up on the GRCS if I’m high enough. The rigging is usually off when it’s getting down to 500i and 661 chogging though .
I dont do much rigging.
To be honest if its time to swap saws I 'd usually set up a friction saver, go down for a coffee then back up with the saw on harness.
Why don’t you negative rig huge pieces onto vast expanses of rough, bare earth to put on Instagram?
