Hi
my little reverse drive tractor has lost its drive and it’s traced to hydrostatic drive unit
the parts are available but bill for fixing could be 3000 to 5000 £
any ideas what I might get for it as a non runner ?
where best to find a replacement or just give the go ahead to get it fixed
I don’t have the time to or really knowledge to buy a better one in the sub £7 or £8 thousand bracket
Whats the way forward ?
thsnks
david
Spend the money get it fixed and do all the other jobs on it that need doing brakes lights paint service the engine give it a good clean = new ish tractor and fix the seat should last a while
  • 3 weeks later...
With any tractor it's usually the better the devil you know and you also know how well it's been looked after.
As has been said, by the time you've split the tractor and replaced whatever is needed, it'll need a jet washing and paint.
Once it's running you can then decide to keep or flip it, personally used equipment once repaired is best kept until it's fit for the scrap.
2 hours ago, stevemarkovick said:
In today's market, even beat-up compact tractors are fetching surprising prices, but selling it as a non-runner might only get you a few grand at best depending on the model and condition. Personally, if you like the tractor and it suits your work, I'd lean toward fixing it properly. As others have said, take the opportunity to freshen everything else up while it's apart—brakes, lights, service the engine—and you’ll probably get a good few more years out of it for a lot less than the cost of a decent replacement.
I'd beg to differ, prices are considerably down on their peak of a couple of years ago.
  • 1 month later...
  • 3 weeks later...
I’ve had similar headaches with alpine tractors—great machines on paper but a nightmare when electrics or hydraulics act up. Parts availability and vague diagnostics make things worse. I started logging every issue by hour mark just to spot patterns. Might be worth looking into aftermarket support or even swapping to a simpler, older model if downtime keeps piling up.
What brand were you running?
I seriously considered replacing my old battle scarred Zetor 6748 fitted with, winch,crane,loader,forks,and anything else euro 8,  with one of these just because the old Zetor was a bit overkill for just pottering around the yard and close proximity, initially it looked good but after a while issues such as mentioned here started to surface and I decided the old zetor was a more reliable bet, so I kept it and bought a garden tractor with a tow hitch instead, just for moving smaller gear around. I can mend both of those without a laptop plugged into them.
