Hi
I’ve a McCormick g30r reverse drive model
its lost its drive  the input to the hydrostatic unit is turning but tractor barely moves. In low ratio it just about creeps about
Mechanic has drained hydro oil and found metal in it so things looking bad
if dealer can’t supply a new unit any ideas where I might find one?
Thanks
david
You need to do some digging, I looked at one of these tractors, I belive you can still get the part as I made a phone call to  mccormic and you could, but also I did see one of the other alpine tractor brands poss bcs (blue) that was the the identical copy of the red mccormic.
Bcs, alpine, Ferrari and mccormic were all the same at one point
Has the hydraulic oil been changed recently before It's failure?.
Whilst no experience of the alpine, the tractors of a certain vintage had a very particular and specific oil that was very expensive as the usual uto wasn't suitable.
23 hours ago, david lawrence said:
Hi
Thanks
david
Had my hydro unit rebuilt cheaper than new was bearing gone and spline stripped
None of the above. The g30r was built for McCormick by valpadana.
McCormick were a mainstream British tractor manufacturer. The g30r was just a badge engineered model to expand their line up.
I knew it was one of those brands, hence why I said some digging needed, I believe I looked at that machine a while ago because it was being sold with a faulty gearbox... It was rebadged. I'm sure bcs did handle valpadana at one point, but it was blue..... Saw one once for sale on FB.. But parts where available  from bcs or valpadana... We looked into it but after research and being told it'd be an expensive repair.. I stayed away!
  • 5 months later...
Back again. Decide to have it fixed
various bits inside hydrostatic drive required
unfortunately one bits on back order at McCormick dealer and been waiting 6 weeks
if I get the part number any ideas on where to start looking for the part instead of just waiting ?
do you think part numbers will be the same across the variously branded version of the tractor?
thanks
david
