No ignition lights or starter connection on Countrax C400 H key change
Tried to change the key starter lock mechanism today and shorted very briefly (small spark) as I fed the new lock into its hole.  Went to start it and - nothing! dead as a Dodo. Assumed it was a fuse but on checking, it was not.  Double checked the three fuses with a mulitmeter. All sound.  Triple checked by putting in new ones. All dead. Checked the earth from the battery. OK. Checked the seat cut out switch (which should not affect the ignition lights - only the running of the engine. No ignition lights. Just to be sure put a wire across the two connectors. Still dead. Went to lunch to think. Still dead. It was working with the old switch (with a screw driver as lock was effed) and put that back in  Still dead.  Battery has 12.65 volts and is fine and fully charged.  Checked with the manual and diagram for wiring to see if there is a hidden fuse somewhere else in the system. Cannot see that.  Took the top off the fuse console to get direct access to the female fuse connectors and cleaned them up a bit and put in new fuses - still dead.
Thoughts.... is there a hidden fuse?  Unlikely...
There must be something very simple that I am missing...
Now pretty desperate as my tiny brain is hurting and its sunny and the lawn is telling me I want to be cut!
Chris George
CA966F2A-78AF-425A-85B9-9D03E6A10428.heic 7175BC2D-E57E-4063-AD9C-459B761F71E2.heic
Are you getting a voltage reading from anywhere in the wiring loom? I would check the battery terminals and earth ( I know you have checked that one) are all clean and tight and go from there.
I will try the battery terminals   Never thought of that
Its obvious but they "look" good and are a robust clip on mechanism. However I will do that right now!
ANSWER found
The key replacement console - although looking identical - actually was a different wiring set up and so was dead as a do do   It was found by (again) double checking with the old key console after charging up the battery.  Now to find out which wire goes to which part of the new switch.  Any countax experts out there with a clue as to how I find the right colours for the new switch? Thanks to those who put in answers
27 minutes ago, cjdg said:
ANSWER found
Often, a session with a multimeter set to continuity test can be a solution. Find the main input terminal ( often the biggest ) and look for permanent live ( probably not needed for anything, unless you have fitted it with a radio 😂) , switched live, and momentary live ( the one that energises the starter ). Switched live feeds everything except the starter. It can be trial and error at first, but not beyond the wit of man.
They'll be off the shelf ignition switches, usually with a number that's easily googled for the schematic.
Either swap as necessary or probably less hassle to find the number and order a swap in key module so you don't have the same problem if this one also fails 🙂.
It's been a while and I can't remember if Westwood used a plastic terminal block for easy wiring, as they're all part of bigger manufacturer groups so economy and efficiency of their thing.
Edited by GarethM
Thanks for all this.  I have ordered a new one from a different supplier Its £45 with the postage but it has taken me a day and a night of worry and lots of head scratching. Never for a moment suspected the ignition console  but on looking at the back they are different.
Ouch, you definitely overpaid but if it's a bolt in part it's worth it for the lack of messing around.
