  • 0
Question
  • 0
It’s been hammered before.
If you don’t reduce those slender leaders at some point you might have problems, regrowth is never as well attached as naturally grown limbs.
  • 0
I'd say it needs cutting back a fair amount. If nothing else, I'd want it to be within feasible picking height for the fruit.
By the look of the structure of the tree it's been cut back rather too aggressively in the past, and then over-compensated with regrowth. It'll need a carefully staged gradual reduction this time to avoid that happening again.
  • 0
The vertical ones at the top I assume you mean.
Is that all you would suggest cutting back?
  • 0
We have owned it for 4 years and not cut it back at all. Ironically, the previous owner was a tree surgeon.
The tree is too high to really pick anything. They are firm pears and so often good even after the fall.
  • 0
I would bring the ‘shoulders’ in as well.
  • 0
49 minutes ago, Rustington said:
Any idea on sort of cost for a job like that?
Very little. That's a 'pop in on the way home from a bigger job' kind of thing. I'd be thinking around 100 quid if it was easy to get to, plus the VAT.
