Rigging alternatives
Con
11 minutes ago, 5thelement said:
I use one of these for self lowering, rated up to 500kg but tested at 800kg, friction easily adjustable or it can be locked off
Now that looks a bit more useful. 500kg is a big piece. Do you often do that much from up top?
Have you tried a crash gybe preventer to compare it to?
19 hours ago, AHPP said:
I didn't want to shoehorn into this thread with a me me me post but it's absolutely relevant so I will. I'm building a rigging device. It's the best thing in this thread by a long way and the best new thing for tree work since the GRCS and the rope wrench. I suggest everyone puts £100 a month in a piggy bank and waits for my signal. If it's shit, you'll have some money for something else. But it won't be and you'll want it.
Tell us more go onnnnnnn
I generally only use it for lighter stuff over buildings, I can control the swing and then let it run/or lock it off then lower it with a tag line attached for the groundy to control, not used the type in your image.
It says max 250kg on the side!! Either way where can I get one?
1 hour ago, 5thelement said:
My mistake, 250kg not 500kg, it was tested to 800kg though, the company is based in Bordeaux.
It's that WLL or MBS?
3 hours ago, peds said:
Tie off the piece, remove slack through the ID, lock off, snip piece, lower away.
I can see orientation as a possible issue. Aside from that i suppose there's nothing to prevent you. The WLL of 250kg kept in mind.
Just consider that it doesn't take much before 100kg becomes the equivalent of over 250kg with a bit of momentum.
IMO there are better tools for the task.
3 hours ago, AHPP said:
Can you post a picture of what you mean please.
I can't be arsed tonight. Basically thread the rope through the beckett of the pinto and over the pulley and back down. Very similar principle to the rig n wrench.
In essence your groundy can lower stuff that would otherwise need a wrap to a wrap and a half on the bollard.
