Log burner at my partners house suddenly has no draw. The chimney isn't lined and we heard an noise like falling soot so think that the chimney outlet is stifled with soot! Just trying to see how it comes apart to clean out or at least check for an obstruction!
That looks very much like my Narvik.
It took my chimney sweep a little while to figure out how to open up to get the rods up - said it was a bit fiddly but I wasn’t there to watch unfortunately
There will normally be a removeable baffle plate in the top of the stove so open the door and see if there is a plate either bolted, screwed or just registered in to the stove. This plate should be removed and then the flue swept. I usually work out the rough height of the chimney and then translate that in to the number of rods needed.
If there is an additional damper in the flue above the chimney, that needs to be removed and is usually a case of holding the damper plate and rotating the handle so it can be withdrawn through the plate and flue.
I have had three stoves and one plate was bolted, the other two were Stovax and they were registered on the rear wall of the stove and two lugs on both sidewalls.
I think that the baffle plate is secured with a couple of bolts at the back. I noticed that the heat etc has damaged it so might have to get a new one! The chimney isn't lined so sweeping it would be a complicated job in a victorian terraced!
Can't think why it would be complicated to sweep an unlined chimney, they were all unlined until relatively recently.
Get a recommended sweep in if you don't want to do it yourself, otherwise just undo the stove pipe, lift it up and drag the stove out of the way.
There's likely to be soot on top of the baffle plate inside the stove and possibly fallen bricks on the register plate. None of that is hard to deal with either diy or paying a sweep.
If you do it yourself, use a soft nylon bristle brush with no discernable central boss...see below. Use flexible rods and always turn clockwise so the rods don't come undone. The Victorian chimney will have a few bends in it as the upstairs bedroom fireplaces impact on the straightness but it should be OK if done right.
This type of thing: -
shopping?q=tbn:ANd9GcT0V5ygRpuRAP_trXxoiRZCEm6u5pb8bQDBUsRTNqq1HqnfbalinBArHLgA9db-m_n3tnTZtBZfoSPMr7CUBPapT29hEi8w&usqp=CAY
Falling soot  - did you notice anything on the grate afterwards, that would indicate falling soot
Was just going to add to Spudulikes comment, our house is fairly standard 2 story and I recon on using 7 1.5m flexible rods to sweep it (I think, might be 😎
You say the chimney is “unlined”? Presume stove pipe terminates into some sort of register plate at the base of the chimney? That’s not a good practice because the original brick built chimney would be difficult to clean thoroughly and this could lead to any unswept soot falling down to the register plate and catching fire from the burner? If you have a small fire on top of the register plate it could lead to more soot and tar falling from the flue and feeding the fire. The existing chimney should be lined, either with a flexible liner or propriety interlocking concrete/ vermiculite liner? There are other systems.
The baffle came out, along with a lot of soot! The firebrick liner is in need of replacement and her lad is going to line the chimney this weekend, weather and ladders permitting! He is a qualified installer of such stuff!
  • 1 month later...
I’ve just bought a pack of three brushes from toolstation. They have the larger wooden centre part, and traditional black bristles. Why are they not going to be suitable? 😳
