54 minutes ago, spandit said:
I saw some that you shouldn't twist wires when crimping
That's right the wires entering the crimp must be parallel then crimped. Twisted wires prevent the crimp compressing uniformly.
Not heard that, could be true in theory but equally never had a wire failure caused by twisting. I'd say I often twist, makes it easier to get all strands in, but not worried.
In practice I haven't had a problem either way on automotive stuff, I think it is more important with high current solar PV cables. If you think about it most crimpers don't uniformly compress the wired into a perfect circle which is why you don't want strands crossing at the crimp, no harm in twisting to get everything into the crimp as long as the crimp is on parallel strands.
Hi Sur, ah done and soldered, and wrapped wi tape, all is good, after I found an innocent looking and dry and clean but defective connector block in the engine bay.
EDIT
To say that while I worked at Wrightbus, I was intrigued to notice that the wires to the various roof mounted speakers, were soldered to the speakers, but these were the only wires that were soldered! And with the vast quantity of  highly flammable cleaning and priming solutions used Willy nilly  prior to applying adhesive, therefore  "hot" work was strictly prohibited. But, hey, solder those wires. With a very cute Milwaulki (Spelling?) batt powered soldering iron.
I asked why? But nobody had an answer.
Edited by difflock
