Just now, organic guy said:
Bigger hedge = bigger satisfaction !
Need some advice on how much to trim off each upright and also need a huge amount of stakes and binders, which I'm not sure I'll have available
Depending on what you want to achieve you don't have to use stakes and binders
It's along a road - think it would look better. Going to be tricky cutting anything off as there's little to no verge
Tell us more please.
First question is does it need to be stock proof?
Does it need to be attractive?
The smartest and most stock proof is Midland, which is basically what you have done. It is also the most labour intensive and requires the most materials.
The simplest and requiring the least materials is what we do on the farm which is a poor imitation of Devon or Berkeley style. Pleached over , laid close to the ground and held in place with big bale string.(which will be removed next winter.
The stakes and binders are only there to hold the pleachers in place, make it more stock proof and attractive.
For a low hedge you could crook it like Devon style, higher you could just stake it as in some of the welsh styles.
have a look here
WWW.HEDGELAYING.ORG.UK
I've done some tying bits in on conifer hedges (for screening) using sisal string, my logic being it's strong enough for one year and then rot away so no need to remove it and no plastic pollution. Would that work? You can get 6mm rope too.
Good idea, the only sisal I've got is Binder twine, must be 60 + years old and not thick enough.
Big bale string is a cheap waste product but does require clearing up, in some hedges most of the strings are chewed through by rabbits by the next winter.
I do that on apple trees.
