Im confused
I thought a  narrow kerf & smaller pitch  would be  best is for not bogging down with batteries?
Also be less  snatchy on small wood....
Also lopro  comes in   2 different bar  gauges...
Edited by Stere
3/8 .050 gauge.
I assumed that a full chisel chain would be a more efficient cut than a semi, added to the fact that I reckon it’s easier to get it bitchin’ sharp than some chains, so I find it works on battery saws very pleasantly (ymmv)
If you try to bog it, it will bog, so whilst cutting, some skill does get involved occasionally.
The stock chain is unpleasant to sharpen, plus getting it nicely tight seems to be problematic.
I've got the rear handled version mate, and I initially found the same thing.  I knock the gullet out of her every other sharpening, and sharpen it at a less steep angle and it's fine now.  They don't really last that long on anything dirty, but clean 20cm hornbeam she'll just need a quick sharpen when I change over batteries.
21 hours ago, Mick Dempsey said:
The big plus is the lack of noise
It quotes the noise level at 106dB which is 1dB less than a 550xp 🤨
I think it’s the silence between the cuts, aiding communication, that he is getting at, not the actual dB level.
That, but also consider that the dB scale is not linear, and each 3dB increase represents a doubling of sound energy.
I was wondering about that.
I tend to use my ears to gauge noise.
is it uncomfortably loud? Yes/no
