I had a large ash felled last year, and wanted it milled to try to make some furniture. Is there anyone local that would do this? If so, what would the cost be?
I've also got a couple more ash that need to come down and I'd like milled also. Plus there is plenty of larch that needs to be felled (and an American lime, and loads of chunks of poplar), where I don't have a use for the wood, if anyone local has any ideas what we should do with it, or wants to trade off doing the felling for the wood?
Try posting what area you are might help.
8 minutes ago, topchippyles said:
Only had 2 hrs sleep last night bloody knackered 🙃👍
Thats 2 more than me . Kept hearing a thumping sound in my loft . discovered today after removing flooring and walling a fcuking mouse has partially chewed through a wire . Not enough to blow the fuse but it kept arcing . looked like a row of tiny LEDs flashing . Will repair that tomorrow ./
  • Sad 1
Thanks. I'll check out those options. Kniveton is fairly local, but the others seem a bit of a trek for a small job. Are there any other suggestions in Derbyshire?
  • 1 month later...
Are you anywhere near wirksworth? Know a guy who has a mill if you can get it to him or pay him to pick it up with his forwarding trailer. He may be i terest in the larch as well
