Timberwolf 18/100 g coming out of long term storage - spares.
I have a Timberwolf 18/100 that has been stored in a barn for the last 10(ish) years, hasn't done very many hours (owned by a charity) I need to source new drive belt, filters, spark plugs, and flush out the fuel tank, where is the best place to buy spares in East Sussex? Anything else I need to do to drag it back to life?
Thanks all.
Aren't most of those just your usual car spares shop, unless it's more mechanical obviously.
Spark plug is the same the world over, belts the same providing you know the size etc.
Thanks all.
I doubt it will need spark plugs, oil and filters yes, I'd probably just empty th old fuel out and see if it starts okay on fresh. I would check the manual for the oil specification and filters ans use a local car motor factors or ebay rather than dealer prices. If you can read the numbers off the belts then a matched set from a bearing supplier.
