I've rented lower powered stump grinders, usually dull, and they have been a b*tch to use.
Looking at getting one next year, saw a Laski with a pivot on it at a trade show this year, 23 hp Kohler motor and self driving for about what I'd be willing to shell out.  Anyone use something like this?  Happy with it?
I rented a similar spec FSI B22 a while ago. Driven wheels, manual slew (on a bearing or something), same power probably. Lovely thing.
I do very little grinding btw because I thought I hated it. I actually hated blunt rental machines. Sharp teeth and it’s a dream. Thought you might appreciate the input from this side so to speak
Edited by AHPP
The FSI B22 is 14hp, same as Predator/Laski 360sw.
From memory I believe Tycorrigan runs one of these.
I have the Predator and it has earned its price many times over. I also have an HB20, about the same size as the 460 but it only gets used maybe 5% of the time. The self drive is very handy though.
The place near me used to rent out a 360 and 460, and they kept the teeth pretty sharp. I'd take the 460 every time I could even though a few quid more to hire, the extra weight of machine and extra power means it takes a lot less effort to grind, and the self drive is brilliant on slopes, or on and off the trailer.
It is a fair bit longer than the 360 though so access can be a problem. I always say the only reason a bigger grinder is not better is if it won't fit in the garden to get to the stump.
Sadly they stopped hiring it out and just had the 360 so I bought my own cheap one I can put sharp teeth on.
Teeffff, it's all in the teeffff..!
 With sharp teeth, and brisk light passes 14hp is enough to demolish even large stumps.
You need teeth with a good cutting edge as there is no weight and little torque to work with.
Teeth for the FSI are very reasonable from QRMS, certainly not worth sharpening.
