38 minutes ago, AHPP said:
Or a jig with a plane/router/something. What’s it for out of interest?
Probably a neighbourly dispute and a blocked sewer
3 hours ago, Muddy42 said:
Presumably, looking at this from the top and/or bottom of your picture, the bung would be round? If so you need someone with a fairly large lathe.  Mine is not big enough.
Yeah that’s a side profile view
basically it needs to go in a hull opening as a secondary back up behind a blank, guys internally are changing out some valves, opening is below water. I guess it would be easy to compare it to a large bath plug, the pics are the posh very expensive way to do it. 🤔
Cheers
Would an inflated bladder be better ?.
As something that large might be liable to split when you're giving it some with a lump hammer.
Can't remember where I saw it but, it's like an expandable bellows with a big arse bolt. Maybe attach it to a plate, so you've got plate/mastic/bellow and internal bolted blank ?.
Edited by GarethM
Client has asked specifically for a softwood bung 🤷‍♂️
It’s only a back up option. If it’s too difficult to source it will probably be a different option, timber bungs that size or smaller are a PIA subsea as they always want to float away.
If you do find one, think we deserve a YouTube video of the poor sod fighting it as it tries to float away 🙂.
