I usually get bits from L&S engineers. I need to replace the screws on the carb or get a new carb but L&S have been out of stock for some time and can't get a date off them when they're likely to get new stock in. Who else do people use for the little bits and bobs.
Thanks
View full article
Do you have the part numbers? Assuming they areย  special carb screws? If they are plain metric standard ones I would go to ebay.
Any local dealer should be able to get them. For online, radmore are a good shop, try their parts page?
ย
WWW.RADMORETUCKER.CO.UK
Garden Machinery Spare Parts Finder Use our Spare Parts Finder to look up a part for Stihl, Husqvarna and Makita garden machinery...
ย
Have you actually spoken with them or just expecting them to have in stock a special order part ?.
ย
As per what kram has said, any dealer including L&S should be able to order them and be shipped from Germany or wherever in a day or two.
L&S are pretty much the best for getting Stihl/Husqvarna parts, on carb bits, try Rowena Motors. They have an exhaustive knowledge of carbs and are usually, IMO, very helpful. The only difficulty will be if the carb is a Stihl specific OEM carb and not based on a generic design, you do come across this sometimes.
WWW.ROWENACARBS.CO.UK
Authorised dealers of Walbro, Zama and Tillotson carburetor and carburetor parts for lawn mowers, karts, brushcutters, and other light engines. Based in the UK, trading internationally.
ย
Is it the high/low screws? Send me a pm with the serial number and I'll see if we have them at work. If not I can check with Stihl and give you a delivery dateย
  • ย
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. ย
If you're just starting out and you need business, equipment, tech or training support you're in the right place. ย If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,ย ย then you're welcome too.
ร—
ร—
