IMG_20220807_132736.thumb.jpg.5fa05b8cde785999e524750ad4e8f99f.jpgIMG_20220807_140805.thumb.jpg.ecd429c99c8ba48948adf0403b992b95.jpgIMG_20220831_190110.thumb.jpg.7ebbede1299206b5fced9b8254f711c3.jpgIMG_20220903_123325.thumb.jpg.8d2a9b35bc43fa76c4aeebccd6f6d1c6.jpgSome old pigwire and a bit of pallet wood. Ideal if you're tight for space. Modular design add more rings for greater storage. With the addition of a little conical roof makes a prety weatherproof option
19 minutes ago, GarethM said:
Or you just buy an IBC cages, modular off the shelf and infinitely stackable for £25.
Aye. But i just used what i had🙂
and getting IBCs into a back garden might not be so easy for home owners.
I built something a bit more permanent using secondhand (free) fence posts (just cut off the rotten bit that was in the ground) and old pallet wood + some wood stain.  Couple of blocks of concrete to keep it off the ground to stop it rotting and you have a structure that can survive many years. The above is quick and simple, if you put the base on something to keep it off the floor then the air flow is better and the base will last longer, although you may not be that bothered.  Interesting alternative.
Yeah no access for ibc cages but a good idea. I just dry in these stacks and store in covered ricks by the back door.
1 hour ago, GarethM said:
How the hell did you get a two car sized shed in the garden.
It came through before the garage was built. I get the impression you are spoiling for an argument if thats the case take it up with someone else. 😄
I'm not spoiling for anything, I've better things to do with my day. I've 300 of the bloody things stacked up and drying
Well get away and tighten on mate dont let me keep you😄
