Drier in summer i think?
https://www.nrs.fs.usda.gov/pubs/nh/notes/nh_5_03.pdf
Quote
In general, the weight of a load of summer-cut (June-July) birch and aspen can be
estimated by assuming that half the weight is water. Wood cut in January or
February has more moisture and could be 6 or more percent heavier than the same
volume cut in summer.
Moisture content will vary from year to year so you should calculate it for individual
cases if you wish to be precise. In addition, if you want to compare the weights of
winter-cut and summer-cut wood, the samples should include equal proportions of
top, middle, and bottom logs because of moisture content variations within the
tree.
WWW.SCIENCEDIRECT.COM
Fuelwood moisture content is an important parameter for small and medium-sized heating plants. Optimal storage location...
Quote
Furthermore, moisture content of live trees varies with the season. With downy birch (Betula pubescens) it is highest in the spring, just before the breaking of the buds and lowest in the summer. With Scots pine (Pinus sylvestris) the moisture content is highest during the winter and lowest during the summer [3], [4], [5], [6].
Some serious myth busting there. I stand corrected.
