Hi, I've recently bought a saw that has a ms240 starter recoil and ms260 chain brake need some assistance with identifying which one it is, thank you in advance
Serial Numbers:
11273510500
117566278
I'm thinking its a bitsa . Maybe a 240 with perhaps a 260 air filter housing . I just googled images of both and they look similar in isolation . However it looks like the air filter housing on yours is slightly taller giving a miss match to the cylinder cover . I'm a Husqvarna man so only a guess .
The air filter cover doesn't look right either.  I'd go with 240.
Edit: Hang on non flippy caps.  026? or I have no clue.
Edited by Muddy42
Air filter covers wrong and the cylinder cover doesn't look like a 240 or a 024. The fuel caps make it a pre MS saw. Will need more photos to get even a guess at what it is.
The crankcase is pre 2000 as it has the screw in oil and fuel caps, the top cover is off a later 2000 model as it has the hump in the middle, pre 2000 were flat, the chain brake is off a 2008 260C, the recoil cover is off a later 2000 on MS240, earlier ones had just a rectangle stihl badge on them, the clutch / chain side cover is a chinesium aftermarket. Stubby’s “bitsa” quote nails it, the exhaust looks like an aftermarket too, hard to tell cylinder wise as can’t see any markings on it but suspect that is aftermarket too. The serial number will reveal all if someone has access to the database.
  • Thanks 2
Read more
