Hello,
Wishing you all are well.
I wondered if someone with experience had an insight into this:
I cut a leylandii cypress hedge early May after i guessef frosts were over (east anglia, uk), and made sure to leave a good 5-6 inches minimum of green foliage when I cut, and cut back to the same place roughly as last year.
The hedge overall appears in fine, but is peppered with 'brown tips' at the site of each cut, about a few mm deep at each place.
My intial thoughts and guesses were that, maybe my hedge cutter isn't powerful enough (greenworks 40v) for a clean cut and 'chewed' the hedge a bit, or the blades aren't as sharp as last year and my home sharping not up to par.
Or is early May still too cold? (Leylandii.com recommended pruning once a year in spring or summer).
Thank you in advance for any replies.
(Attached pics)
Regards
I wouldn’t worry, looks like you’ve gone in quite tight, so you’ll get a few brown bits.
Leylandii can’t be kept at a constant width, they have to get a little bigger every year, till someone goes in too hard and the big brown patches appear.
Ah- thank you so much!
So each year they have to get an inch or so bigger.
Thats the difference between reading a website with no experience "cut back to the same point each year" and with experience knowing 'how' to read that ("cut back to the same point-ish i.e slightly less each year").
In that second photo, the close up, the brown bits haven't been cut, they might possibly have been chewed at by a blunt trimmer. Id have happily trimmed that a bit tighter than you have. But I wouldn't worry it will grow out again all to quickly!
Went through something like this a few years ago with a hedge trimmer that you could not tighten the blades ( shoulder bolts through the blades) the blades then tear the the non woody spindly parts of the hedge rather than clean cut it.
The tips will turn brown sometimes no matter how sharp cutter is, had it on a hedge a couple of years ago hedge cutter was brand new and razor sharp.
