We have taken one in for a service and noticed there is no tension on the plastic grass deflector flap (the hard plastic one you lift up when you fit the grassbag- not the rubber flap underneath the rear end of the mower) Spring is still present but is just flopping around loose on the securing rod to the body. I cannot for the life of me work out the correct way it should be fitted. Not being a Honda main dealer, info is somewhat short to obtain and I don't have another one of the same to compare it to.
I have googled, you tubed and obtained a parts list, but nothing is clear as to its orientation. If anyone has one on here can you take a couple of pics how it should be fitted?
It's been about ten years, but I remember I had to pre tension one on an old plastic honda and slide it together.
If you didn't the spring wouldn't do it's thing.
4 minutes ago, daveatdave said:
i think i have the same mower i will look in the morning but never had anything to do with the flap spring.
All pics are really helpful dave. Cheers
