Hi does anyone know where there is stock for replacement chains for the echo 2511tes 10inch carving bar? Normally got it off a guy on eBay but it’s out of stock and can’t seem to find any online anywhere.
spec follow as:
10" Echo Carving Bar Panther Mini Chain 1/4 .043 60 Drive Links
thanks
2 hours ago, Dan Maynard said:
Chainsawbars is the place, they do custom loops where you enter the pitch, gauge and number of drive links you want
WWW.CHAINSAWBARS.CO.UK
  Select your pitch & gauge for results. This will be joined chain.
If not then send Rob a message or WhatsApp, if anyone can sort you it's them.
Ok thanks Dan will do that
spec follow as:
thanks
Are you after the stihl/panther chain or is it to fit the standard echo 1/4 carving bar?
If it’s for the standard echo bar it’s .050 or 1.3mm rather than .043 or 1.1mm which is the stihl chain
The standard echo carving bar comes in .043 or .050 gauge. They look the same, 60dl, 1/4" pitch but the gauge is different.
.043 echo chains are here
SKYLANDEQUIPMENT.COM
Only for use with the 1.1mm 1/4" guide bar. Please check before ordering Echo chain for certain models of the CS2511...
This is a cheaper alternative
Husqvarna X-PRECISION™ SP11G is a semi-chisel ¼” mini 1.1 mm chainsaw chain developed for precise and gentle pruning...
.050 chains are here.
Get your smallest jobs done just right. 25AP is lightweight, smooth chain, ideal for pruning — our Micro Chisel® cutters...
