On 30/10/2023 at 06:43, GarethM said:
Unless you're in the depths of nowhere is it really worth buying a set when it's about £60 for a sweep ?.
Plus they can check for damage with a camera.
Coming back to this thread..... £60 for the sweep, similar for the brushes but the advantage is I got up this morning and didn't need the fire on first thing, took the chance to give the chimney a quick clean - can't do that with the sweep "come round right now while the fire is off" (the chimney was about 18 months overdue, but only half a carrier bag of soot and ash, so not too bad)
Whilst you can do it yourself more regularly if you so wished.
£60 Vs the 100+k for rebuilding your home after the insurance say you've not swept your fire and won't payout seems cheap.
The main point being of course that regular sweeping by someone will reduce the chance of a chimney fire so that it will never happen while I am fit enough to do it once a year myself. The second time each year depends if I can get a sweep with availability as to who does it.
That's my approach.  Once a year by the sweep and then I give the open fire a second clean in January.  Just done it and brought out about a bucket full (including a jackdaw feather and a stick - the B@stards must have been poking stuff through the protective grill I have). I find if I don't give the open fire a second clean, the draw gets reduced and it can smoke back into the room slightly. Also the sweep won't go on the roof, so I try to get on the roof before he turns up.
