Never seen a green plug before. What does it mean?
Plug has just had a heavy ish couple of weeks in a 661. Pump petrol and Stihl Ultra, mixed a tiny bit rich, very fresh.
1 hour ago, openspaceman said:
Nor me but I'd say that was running weak
Do you mean lean? As in too much air to the fuel.
56 minutes ago, GarethM said:
Is that a name brand spark plug, as I presume it's leeching out the copper from the electrode ?.
NGK
37 minutes ago, openspaceman said:
Yes it looks like it has run over hot and that is normally due to an excess of air to fuel.
I'll adjust the ECU with a screwdriver.
The green has got to be copper. A mate suggested it might be added to fuel instead of lead as an antiknock additive. Can't find anything to support that but apparently there's a bit of copper in petrol anyway.
