Hi,
We have a building project coming up on our own woodland and are planning to remove a couple of hundred sitka spruce stumps which are on flat ground.
We are looking to buy a used excavator to do a lot of the groundworks for the building project [foundations, service channels, drainage, gullies maintenance, felled log handling etc] but also to remove some of the sika stumps.
Question: Would a 6-8T excavator [with thumb] manage the stump removal ok, accepting that it may take a little more effort/time than say a 16T machine?
Thanks
Alec
Edited by Alec_Birkbeck
10 minutes ago, Alec_Birkbeck said:
Most are around 20-25cms Diameter, thanks
You’ll piss that with a 3t never mind a 6t.
If you’ve a lot to do, get a ripper tooth.
If you’ll be log handing, get a grab. A grab will be all you need to pull those stumps.
Are the trees already felled? It's a lot easier to push the tree over then cut the stump off if that's an option. Although on small diameter trees it shouldn't be too hard either way.
20cm 25cm and the odd bigger one could all be done with a 6 - 8 tonne machine with ease, i have done many areas of stumps that size with a 2,7tonne machine with fixed grab,, no matter how big the machine is, it is only as good as the operator working it,
