1 hour ago, Muddy42 said:
I am no expert on all this, waiting to hear from people who are!
TCD was the expert but sadly no longer on here . He was a fan of Red Line Racing 2t oil as am I .
Edited by Stubby
No particular dog in this race! I've run dozens of 2 stroke small-engined machines over the last 40 odd years-mainly stihl and kawi machines.Often run hot and hard for extended periods commercially.Always used stihl red mineral oil @50:1 with no issues I could discern.Occaisonally had carbon breakaway shorting the s.plug intermittently at full speed on high hour stihl clearing saws-no big deal tho.As machines get more expensive and less tolerant re:E5?Changed to the semi synth stihl super green oil @40:1,again,no great differences noted commercially,I wouldnt use the stihl ultra just on price premium tbh.The super if bought at 5 litre quantity,pretty much compares to the price of a single litre price of the mineral oil anyway,and hopefully is a 'slight'upgrade.
Also,no way could I even consider using the motomix cans regularly,even as a one man band,its not unusual to to use 20 litres of 2/+4/ a month.But if I buy a high-end 2/ machine-or 2 at the same time-I may buy a 5 litre can of moto just to treat/break them in-whether there is any sense/logic in that,I couldn't honestly say!
Here's a mad thought/interesting experiment-buy your 5 litres of standard E10 petrol+add your chosen mineral/semi synth 2/oil,Then mix in a litre of moto on top!?That way,you are hedging your bets re:different 2/oils+diluting the ethanol content+making your moto go 5 times further too!Dont thank me,I can hear the applause from here 😄
On 22/05/2023 at 13:48, Bob_z_l said:
Good point.   The US have their own mixes of fuel. ...
Reaching out in the hope that  @Crocky has some comment....only based on the fact that he'll be looking at the insides of my 261 that has almost exclusively run on E5 pump fuel and Ultra 50:1 or as near as dammit.
I don’t use Stihl ultra for the same reasons as is mentioned on that YouTube video. I use E5 fuel and Stihl HP super. I’ll let you know what the pistons like when I pull it apart but I’m pretty sure it’ll be coated like the one in the vid.
I have pics of inside two cylinders, both the same saws. One ran on aspen’ and one on two stroke mix. I’ll find the pics and post them soon. I’m not a fan of aspen’ (personal preference) but it certainly burns cleaner. My only issue with it was the bottom end looked dry.
Edited by Crocky
A thought provoking topic.I'm no oil expert.But if you look at cars we have moved from mineral to semi synth,now fully synth oils.No modern car's service schedule would spec mineral oils I assume?Again,I assume fully synth oils flow/warm quicker due to their lower viscosity?So minimise start up/cold engine wear due to better initial warm-up/ early movement thru the engine.Which sounds logical....
Oil spec on current car engines is all about fuel economy and emissions reduction (so thin oils for lower viscous drag) - not necessarily whats best for engine longevity. But then again modern engines are generaly good enough to last the warantee period and then some so theres some flexibility there.
