I've got the Harken ninja which I think is a red jet step, I reckon it's really good as very very little resistance to rope falling through. With a little care it will pull through on a foot or two of rope, so you can pretty easily get off the ground without having someone hold the tail down.
Also good in the tree if you've crossed a branch as you don't need to pull a big loop below you to start moving up.
Bit expensive but worth it is my conclusion. I'm currently trying to use it more as recently spent £200 on physio so need to change my style to be kinder to my shoulders.
They are both the same.
Love the Notch.
Teads from the ground and is easy on the rope.
Harkern and the Notch are the same so would go for which ever one is cheaper.
